RG-EG105G-P how to restart DHCP server Reply
Jacques Rossouw
3307 4 2025-1-10 18:13:27
Hello Support
I dont want to restart RG-EG105G-P, only want to restart DHCP Server
RG-EG105G-P
Cloud Router
0 2025-1-14 11:22:58 Solved View all replies
Jacques Rossouw replied at 2025-1-12 19:35
Please post picture of location
Hi, this is the location in eweb
and this is the location in cloud
0 2025-1-10 21:33:01 View all replies
Hi, if you enabled dhcp server on EG, you can disable dhcp function, then click save, and enable it again
0 2025-1-12 19:35:11 View all replies
GTAC-Rachel replied at 2025-1-10 21:33
Hi, if you enabled dhcp server on EG, you can disable dhcp function, then click save, and enable it  ...
0 2025-1-14 19:27:34 View all replies
Thank you
