Where can I find the LOGs of VPN connections on Reyee routers? Reply
Renato Vieira
3696 3 2025-3-3 18:28:28
Hello, I would like to know where I can find the LOGs of the connections made by users to VPNs?
For example, I have a VPN with PPTP and I need to know what time and what login attempts my user had. Is there a specific place to view these LOGs, or do I have to activate some function?
The idea is to collect the following information:
Login time
How many attempts
IP ADDRESS
Username
Connection type...
My router is a Reyee RG-EG1510XS.
Do we have these LOGS? If so, where can I find them?
Thank you very much.
RG-EG1510XS
Router
0 2025-3-3 23:13:51 Solved View all replies
Renato Vieira replied at 2025-3-3 20:19
Thanks for the quick reply, but is there any other place to store the LOGs? Because this router sp ...
Dear customer,
Sorry, currently the logs settings for it only supports traffic log, DHCP log, authentication log and NAT log.
We will submit your request for the VPN log to our R&D team.
0 2025-3-3 18:35:03 View all replies
Dear customer,
You can download the VPN log from the eweb of your device.
0 2025-3-3 20:19:27 View all replies
GTAC-Ryan replied at 2025-3-3 18:35
Dear customer,
Thanks for the quick reply, but is there any other place to store the LOGs? Because this router specifically has a hard drive, if you direct it could store this type of VPN LOG, too?
