Help with setting up M-Lag Reply
eromanov@rubyte
7070 1 2021-6-7 18:43:56
Edited by eromanov@rubytech.ru at 2021-6-8 15:53
There is an RG-S6510-32CQ. How to configure M-Lag 40Gb on it?
0 2021-6-9 19:16:36 View all replies
I have enabled the protocol spanning-tree v-stp enable and the information indicates that Mlag is disabled.
R2#sh spa v information
V-STP status                 : enable
Local bridge mac             : c0b8.e674.34d0
Selected bridge mac          : 0000.0000.0000
Peerlink Port                : Virtual-port
Calculate Virtrual Index     : 4095
Mlag Remote device connected : N
MST 0 Root Port         : None
Two switches are connected by 40G and 1 aggregated port is made.
R2#sh aggregatePort 1 summary
AggregatePort MaxPorts SwitchPort Mode   Load balance                 Ports
Ag1           16       Enabled    TRUNK  src-dst-mac                  Hu0/1   ,Hu0/2
R2#sh vrrp brief
Interface             Grp  Pri   timer   Own  Pre   State   Master addr                               Group addr
VLAN 10               1    100   3.60    -    P     Backup  10.0.10.11                                10.0.10.1
VLAN 20               1    120   3.53    -    P     Master  10.0.20.12                                10.0.20.1
VLAN 30               2    100   3.60    -    P     Backup  192.168.0.11                              192.168.0.10
R1#sh vrrp brief
VLAN 10               1    120   3.53    -    P     Master  10.0.10.11                                10.0.10.1
VLAN 20               1    100   3.60    -    P     Backup  10.0.20.12                                10.0.20.1
VLAN 30               2    100   3.60    -    P     Master  192.168.0.11                              192.168.0.10
what is the problem? HELP ME!!!
