Official
How to configure Ruijie AP authentication? Reply
admin
Level 5
14395 0 2022-4-19 10:22:02
Please perform the following steps after AP is online on Cloud:
a) Enter the wireless basic configure page and choose the ssid need the authentication.
b) Enable the ‘auth’ in this page.
Only the AP captive portal need to enable the ‘Auth’ in this page.
c) After enable the auth, chose the portal template to be used and set the seamless duration.
d) After lick the ‘OK’, the auth mode has been changed. In the end, don’t forget to click the ‘save’ option to save all configuration.
e) The connected users of this SSID will get the portal page. They can access the internet after pass through the authentication.
config others
