RG-RAP2200F - POE Passthrough Reply
Barghest
3994 1 2024-1-22 16:57:03
Does the RG-RAP2200F access point provide for POE passthrough to the 2nd LAN port or will the attached device require it's own POE injector (which seems nonsensical as it makes the addition of a device to the port redundant if it needs its own power supply)
RG-RAP2200(F)
Specification Other Wireless Technical Introduction Configuration
0 2024-1-22 17:10:52 Solved View all replies
Dear Craig King,
Please kindly note that the second LAN port on the RAP2200(F) does not support PoE, it cannot provide power to the attached device. However, if you connect a PC or a device with an independent power supply, the second LAN port can be used to transmit data.
Jayden
